It is very important to quote the engine number when ordering spares or making enquires about your engine. To identify your motor, click here or the box at the bottom of the page and search the lists for your I.D. letters, these are the first set of letters in the sequence. i.e. 'AD' That will give you the type of Seagull, (102 direct drive), the number in some early cases will give you a rough guide to the year. Note the numbers ran through several different models that were being built at the same time. After 1963 there was a letter and number at the end of the sequence to denote month and year A = January 3 = 1963. In 1973 the codes continued with double letters, i.e. AA 3= January 1973.
To add to the identification problems there are anomalies. For instance Seagull used the letter 'R' to denote a motor had been reconditioned, but there is no indication when the reconditioning might have been completed. (Just to add to the confusion they used 'R' on some very late models with the ill fated roller bearings). The letter 'L' was used to denote 'longshaft'. In early years this was added to the end of the number code, later, from 1963 it was added to the prefix, i.e. FPL,= Forty Plus Longshaft. Watch out for the E for electronic ign, the G for Bing carb or the A for Amal, all prefixes!
Another problem is the inconsistency in the letter codes for the months. Seagull did not use some letters as they could be confused or were in use elsewhere, so there are no letter I's, or O's and it should be that December equates to 'M', however the letter 'N' has been found, so perhaps they lost another letter at some point? I do believe they did not use the letter 'L'. Sadly when these pages were thrust into my hand, as I cleared the factory, there were no explanatory notes.
Thought you might like a few pics of a cutaway model I have. Produced by the Villiers apprentices about 1970.
Pics by courtesy of Classic Boat Magazine.
To trace your engine number, click the here or the "Don't Forget" picture at the very bottom of this page for an explanation and a list of engine numbers by model.
Then use the buttons on the left or at the top of the page to see more details of your model.
Details from an old Seagull poster
Horse Powers
There has been a lot of myth and nonsense surrounding the power output of the Seagull. There were, in the classic range, two power units, a 64cc and a 102cc (the original 102 cc motor of the 1930's existed alongside the later Century and Silver Century 102cc units.)
By fitting a variety of different gearboxes a range of power outputs were obtained. They classified them as follows.
Square block models.
Forty minus :- 1 to 1.5 hp, later as 1 to 2 hp, or later still, (before being called the 45), just 2hp.
Forty Plus (direct drive):- 1.5 to 2.5 hp, later as 2 to 3 hp
Forty Plus, Clutch Drive:- 3hp
The Century:- 4hp ( Villiers carb.)
Silver Century, :- 3 to 4.5hp (Amal carbed version of the Century.)
Century Plus, clutch drive 4.5hp.
Silver Century Plus, clutch drive, 4 to 5.5, later 5 hp.
When tested none of these motors gave the rated output, indeed they struggled to achieve more than 1, (yes ONE), horse power!
Other motors
Model 102, Direct or Clutch drive:- 3.5 to 4 hp
Model 102 Plus Clutch drive:-3.5 to 5 hp
Model 170:- hp not given as after 1980 Trades Descriptions Act! believed to be 7.5 hp!
Model 125:- again not given, but approx 5 hp.
QB curlew:- 4hp
QB Osprey:- 5hp
QB Kingfisher:- 6hp.
(There was one other, the ill fated twin cylinder motor of the 1930's, that gave 10hp!)
As you can see, there was only one 6hp model and only a couple of others, both ill fated, that gave more. It was the slow running props that gave the push, that made Seagulls useful. They were designed to push heavy loads at displacement speeds, all day if needed.
The origins of the model Numbers.
It seems that the change was instigated when the ‘Trades Descriptions Act’ was to become law in the UK. It was found that the vague hp ratings of the motors were a little awry. To comply with the new law it was thought that the thrust at the prop, (measured in pounds of 'bollard pull'), was more important, thus the ‘Featherweight’ became the ‘45’ and so on.
The ‘Silver Century Plus’ they developed into the ‘Model 110’ by the inclusion of the reversing gearbox fitted to the ‘170’, (thus escaping the duff con rod syndrome)! The ‘110’ number was given to make it one model up from the 100, or ‘Century’. This model was numbered down to ‘90’ when the thrust at the prop was measured. The ‘Model 90’ became the ‘Classic 5’ in the last days of ‘Chillington’, but sadly was dropped, one reason was the selling price, over £1000, but the final nail was the loss of the tooling for the gearbox cap, which is still unobtainable. (Fortunately a part that is rarely if ever needed as a spare, and I have some, if needed!)
Sadly, although the new numbers were ‘correct’, I and most others, still refer to our Seagulls by their previous names. I think most of us prefer the old names.
Oddly in the last days of ‘Chillington Marine’ they went back to hp numbers. The ‘Kingfisher’ became the ‘Seagull‘6’. The ‘Osprey the ‘Seagull 5’ etc. Thus it was the ‘Featherweight’ that became the ‘45’, ended it’s days as the ’Classic 2’, the last engine type that was produced, to order only, up to 1996.
By then the codes were getting silly, TSEF prefix was one of the last, it included the information that it was fitted with a twistgrip!
Click box below to see the model identification numbers.
Hello All, thanks for your patience, I have been out of action for a bit, I have had the surgery, which seems to have fixed my ongoing back problem. Fingers crossed! Back to normal parts service now!
John, SOS
To E-mail SOS john@saving-old-seagulls.co.uk or just click the bottle!
(or phone 01621 778859 )
Sorry if there is a slight delay in me getting back to you, I am having so many mails sent in these days...
Please have a look on the FAQ page also the 'I. D. your Seagull' pages, might save us both a bit of time.
If I am not answering the phone, this might give you a clue to where I might be if it's good sailing weather!
UK queries may be better by phone, as I can ask you those extra little questions that might solve a problem easier. (Like why your 102 has a century plus gearbox!)
If you are in the UK it is probably best to phone me
on:- 01621 778859
Copyright: Saving Old Seagulls © 2001
All Photographs and text are Copyright of Sheridan Marine (British Seagull) and/or SOS (Saving Old Seagulls).
Reproduction of any of this site is forbidden without written permission of SOS.
Web Design by Spectrum Systems:- Sadly Barry the Webmaster died 19.04.05
a sad loss of a good friend, taken by Cancer aged 55.
Ver 9/ Last updated - Monday, 08 January 2007
