1 - The plug supplied is a NKG - A7, and the spare supplied is a Champion D16. Whereas I have seen the D16 as recommended, is the NKG just as suitable? It has MK1 Villiers ignition. It is sparking well with either.
2 - The carb (Amal two jet 46N) looks pretty leaky, top and side and bottom, all around. Is this just a set of washers and gaskets required, or are there any other details to address re fuel leaks?
3 - The steerage handle bracket is broken off the port side lower half of the crankcase
4 - The prop seems very sloppy on its shaft. Not end play, or spring slack, - but internal bushing slop. How sloppy is too sloppy (yeah - I know - how long is a piece of string?!?!?!)
5 - The serial number says only "TC" - nothing else. I was expecting more numbers for year and month etc. But there is a 31 J on the cylinder side. Is the "31 J" relevant for ID purposes?
6 - Where the water inlet pipe goes from the pump into the silencer there is a 1/4" pipe with 1/4" hose (about 2" long) with screw clamps on it. Is this a sufficient and reliable enough join, or is there a better system? I have not seen any pictures like it on any other TC102 .
7 - As for the height of the motor, my 22" transom on the 12' aluminium dinghy requires the mounting bracket to be fully up (no collars). At that point the water inlet slots are just level with the lowest tip of the keel, which will be about 6" below water surface, making the exhaust outlet about 5" below water level. Is this a tolerable depth to allow full water force in the slots? I figure, if exhaust outlet is too low I will have back pressure probs, but if the water inlet is too high I may have cooling probs due to the transom blocking the flow. I guess I will find a happy medium once travelling in water.
8 - I am composing a shopping list of tools and spares to have on hand onboard at all times:
Plug spanner and spare plug.
Pulley spanner.
Prop spring, and prop removal tools.
Feeler gauges, emery paper.
Basic drivers and spanners.
LIT08 workshop manual (supplied)
WD 40.
Tube of marine grease.
Is a spare HT lead necessary to carry at all times?
Is a carbie kit ever needed on water?
Anything else I should have???
9 - Oh, and where do I adjust the tappets? (<<<only joking)
Thanks in advance to all who can assist.
