Will not rev
Will not rev
I finally started up my 40+ today. Started Oman third pull. However when I tried to rev it up to high revs ( it's was fine at half throttle). It wouldn't run and began to cut out. Does anyone have any ideas please
Re: Will not rev
It could be any part of the ignition system, fuel system or engine crank or block or even gearbox.
Will need a little more information first, What's the motor like, what have you done so far to it, has it got good compression, pumping water, was it in a tank or on the water.
It could be just about anything, but most common would be the fuel system and carb needing clean.
