silver century carb problem...
hi, just got myself a siver century seagull outboard. it has the amal two-jet carb and the problem is that when I turn on the tap at the tank, fuel starts leaking from the air intake. I have checked the float and its fine, the needle seams to be seating well, but still it drips fuel...its like the bowl is too full but I cant see why, greatfull for any help
- 1650bullet
Re: silver century carb problem...
Have you pushed the float way down. Ive made the same mistake once before. Have a look at the pic i posted up and you will see the pin in the middle pokes threw even further.There are 2 clip positions on the needle.
thanks for that, but I see your float seems to be made off plastic, mine is brass and seems to have only grove in the needle.
- 1650bullet
Plastic and brass are the same in size. There should be two clip positions. Have a better look.
ok will have another look and report back.
definitely only one clip position on my carb, but for some strange reason its stopped leaking petrol now!...so im keeping my fingers crossed
- 1650bullet
See how you go. Keep this thread open if you have any moroe dramas with it.
