Whats the correct procedure for fitting the conrods?
Niander101
Post by Niander101 »
to centuries etc as i notice if the screw is over tightened the rod binds
so how tight for the screws ?
Re: Whats the correct procedure for fitting the conrods?
The conrod should just fall over on its own...
It sounds like you have the end cap fitted the wrong way around.
You will see on your rod, a cast feature right by the parting line you will also see a similar mark on the end cap, these should be both on the same side!
Does your rod have a brass shell bearing location spacer on each side? Is the big end journal in good condition 0.6245" to 0.625"?
The rod big end screws should be torqued up to 7 ft lbs, if the journal is within the above tolerances & the screws at the right torque & it still binds, you've distorted the cap & need to buy a new rod from John.
Niander101
ITs ok now i did notice the little marks
Whats the procedure for changing out the main bearing bushes?
