JAP Seabee query
JAP Seabee query
I have a seabee and before i spend to much time or effort i want to ensure it'll run.
I have started to strip it, i'm happy with the fuel and compression but tested it for a spark today.
I couldn't get a spark, i also can't find any information on the points gap? Also if that doesn't work i'll need to remove the flywheel, is this removed the same way as a Seagull one?
Re: JAP Seabee query
Points I would say around .018 to .020" and the spark plug gap is 0.25".
The flywheels is the same, except it has no key-way, so mark it up before hand or you will have to re-time it all over again.
Great thanks for that, I'll check gaps ant try again before I go for removal. I did attempt yesterday to remove it but it's a stiff one and it didn't budge and I caused a small amount of damage to the thread/nut.
I gather it is a Jap not a ILO, the flywheels are as soft as sh*@ and go out of shape very easily.
It had JAP on it, viewtopic.php?f=17&t=2845Keith.P wrote:I gather it is a Jap not a ILO, the flywheels are as soft as sh*@ and go out of shape very easily.
I'll try and have a quick go now and grab a beer whilst i'm down there.
Right i have just tried again after resetting the points and held a new plug against the block.
I now have an intermittent yellow spark, when i held the plug electrode to the block i got a consistant blue spark.
So it does spark but is weak, i will clean the points again as i have a feeling i'm going to break something if i try and remove the flywheel.
I have cleaned the points and now it sparks well.
I'll leave the flywheel on now and am happy to tart the engine up.
Tart, did you say, just tart it up, proper job please.
Mix a small tins of hammered gold and a tin of copper together, that will make the right colour.
Thinking about it, your right its only a seabee, just tart it up.
As its only a seabee I have bronze hammerite smooth and that will do.
"Only a Seabee"
Even these need some respect on a rack aye?
It should be hammered gold and bronze mix, or gold hammered, If its just an old Seabee.
Hammerite is a little expensive, but think how many seabee's you could restore.
I stocked up on hammerite when I was restoring bigger things, I could get hold of a 750ml tin for £2.99, lucky I did.
