I'm considering an attachment that will let me flush a Seagull motor from the garden hose after coming back from a run in salt water.
Looks like I'll need something moulded to fit the front of the lower unit and to seal around the cooling water intake ports, then a stretchy strap to go around the unit to hold it for a tight fit.
First thought were to cast it from aluminum, making it thick enough in front to take threads for screwing in a hose fitting. The sides would be lined with soft rubber - maybe neoprene - to make a water tight fit, and a "bungee" cargo strap would go around to hold it tight. The amount of aluminum needed would be small enough that I could melt it in my heat treating oven, which is about the size of a counter-top microwave.
Question is am I reinventing the wheel here? Is there something currently available to do the same job?
Gull Flusher
- Jerry In Maine
Re: Gull Flusher
You could go in from the other end (no snickers). I tapped a piece of tubing into the water discharge holes of my motors primarily to facilitate flow at trolling speeds. But I've also used it for flushing residue by clamping a hose to the tube and backflushing.
Scroll down at:
http://www.saving-old-seagulls.co.uk/fo ... f=2&t=1756
Scroll down at:
- Jerry In Maine
Re: Gull Flusher
I thought about that Todd - sorta like a Seagull enema what with going in the back way.
I thought though that if I feed the water from the lower intakes I could run it w/o it sitting in a barrel.
btw: nice boat in that thread. I plan to build one this winter that similar just for the Seagulls to push around on the local lakes. Heading to Portland, ME soon to pick up the marine ply.
Re: Gull Flusher
I tapped one of my blocks at the water outlet for 1/8" NPT, that way you can thread in a short brass 1/8" pipe nipple and back flush with your garden hose, suppose it could be run that way as the impeller does not touch the case sides. [never tried it myself though]
Also allows you to set up for water cooled exhaust should the desire strike you [similar to the 102 setup except for the water outlet location on the Century or Forty] . Like doing it this way better than drilling into the block around the exhaust port, enough of a problem area already, IMO
