Another Marston Bitsa on the Bay
Looks like a bit of a bitsa Item No. 360159616269
But has some good bits.
Yes, it's a bit of a mixture. Same vendor as last time.
Wonder if he'll let me go to have a look?
That Gearbox looks like this one I have on an Olympic. Prop too.
C.I.
SimonT
Re: Another Marston Bitsa on the Bay
Post by SimonT »
Sure does I would love the petrol tank off it :)
Well I would like the water pump housing & carb
Timberman wants the flywheel / ignition
You want the tank
Perhaps I should buy it to break.
I would like the gearbox, as the skeg is better than mine.
This engine is I think beyond economical restoration, but the value of the good bits must make it worth buying to break.
To restore it you would need the correct transom bracket, correct cylinder, fuel tank mounting bracket, throttle lever, tank cap, fuel pipe.
So I agree that those who want bits should club together and buy it.
mick r
Post by mick r »
Twist grip throttle looks a little ahead of it's time :!:
I've just got to have that tank cap :oops:
Mick.
If Simon who want's the tank doesn't desire it, it's yours if you pay the postage!
timberman2004
Post by timberman2004 »
yup, I'm in for the flywheel / ignition.... even the tank ?
I was developing a soft spot for the unique chemist pot fuel cap, but I'm generous, and Mick r did 'bagsy' it first
SimonT
Post by SimonT »
There seems to be a bit of interest in the fuel cap. We may need to set up some form of Seagull race with that as the first prize :lol:
Trying to make a list of what's needed to restore it to a complete example, H-A is quite right it needs a lot.
Cylinder
Tank supports
Tank straps (Jubilee clip version)
Filler cap
Fuel tap
Fuel pipe
Air Intake (can't see carb, may need carb)
Tiller arm
Throttle lever
Complete transom bracket assembly
Tiller wing nut
Prop (that's a later one I suspect, not made of the same stuff)
Tiller grip
and of course we don't know if the crankshaft/driveshaft/pinion shaft is the original..
That's more than half of it.
Not wanting to be a pedant, but it needs a tank support not tank supports!
The original one piece aluminium bracket.
Have just sorted the tiller grip problem,
