HI ITS STEVE ET DOM AGAIN
CAN SOME ONE PLEASE TELL US HOW TO GET THE BLACK BOWL OFF THE
Villiers carb,BEFORE I BREAK IT.!!
Villiers carb please help!!
IT JUST TURNS AND TURNS ??
It's screwed onto the bottom of the centrepiece/jet assembly. Is that turning because the little grub-screw that retains it is missing (see part #11 and #13 in this diagram from John's site
If the centrepiece is not turning then the threaded insert in the base of the bowl has come loose.
Note that the aforementioned grub-screw locates in the machined slot in the shoulder of the centrepiece not the round hole
