The first one im working on is a 102 model TC 72117 which ive stripped down and repainted the block ,
What I need to know is at what stage should the rings be replaced and the bore deglazed , is there a min/max tolerance for the bore and /or rings
Also at what stage do you replace the brass sleeves for the crank shaft and piston rod
The 102 I am doing now started first pull and seemed to run great but ive noticed the brass sleeves looked a bit scratched .
I know i should probably buy a manual but that may be a little while off yet as funds a low at the moment so thought I would ask on here .
I live next to the waikato so next year im hoping to race in the seagull race well maybe put put put anyway
