Hello again,
Apologies for the long silence. I've managed to get some time off work and am back in the UK.
I have managed to finally reassemble to powerhead and get a nice strong spark.
Had quite a few "issues" but are now finally solved. I've decided to leave out the spacer washer and clamp the base plate slightly higher up (like Hugz's picture) .
Aligning the points properly was very tricky. Even a fresh set of genuine Villiers ones needed fettling to line up. I believe my points pot isn't original? It is identical to to Villiers MK1. Most SDs on the forum seem to have one like this:
- IMG_0846.1.jpg (20 KiB) Viewed 4164 times
I am now trying to make a copper fuel line. I'm having difficulty finding a fitting to connect to the Ewarts fuel tap. I
think the fuel tap outlet is 7/16 BSF. I am not sure of this as only have a vernier handy and no gauges. I can only find BSP fittings for sale on vintage car and model steam sites. I am using 1/4 inch OD copper pipe.
- photo__1347185505_82.26.155.62.jpg (8.72 KiB) Viewed 4164 times
Does anyone know the thread and where to get fittings? I've asked George at Villiers Parts with no luck.
Thanks for the help,
