Moderators: John@sos , RickUK , charlesp , Charles uk
Responder59
Posts: 10 Joined: Sat Apr 15, 2006 6:41 pm
Post
by Responder59 » Thu Nov 23, 2006 7:56 pm
My Century with clutch CPC 247 L4 circa1964 suffered an immersion in salt water last year. I have had problems with"the spark" since then.
I've been given a srap Silver Century WSP CL 466EO and I'm wondering if the flywheel unit will fit my engine.
Expert opinion from a Seagull Sage will be much appreciated.
Steve
John@sos
Posts: 639 Joined: Fri Mar 03, 2006 8:16 pm
Post
by John@sos » Sat Nov 25, 2006 5:04 pm
In a word, YES!
You will have to use backplate and flywheel but they are a straight swop.
Regsrds,
SOS
Responder59
Post
by Responder59 » Sun Nov 26, 2006 4:20 pm
Many thanx John. Will it be necessary to remove the flywheels or can I just unbolt the units?
Methinks I need to purchase a workshop manual from you!
regards Steve
John@sos
Post
by John@sos » Sun Nov 26, 2006 5:09 pm
Hi Steve,
yes Flywheels and whole of backplate assemblies will both have to be removed from crankshafts to be able to swop them.....
Waiting for new supply of manuals, should be in this week!
SOS
Responder59
Post
by Responder59 » Sun Apr 01, 2007 7:34 pm
Finally finished the swap!! The recaltricent timing locking screws yielded to a 12 volt impact wrench for removing car wheel nuts!
I now have a nice fat spark, fresh fuel but no start, not even a feeble cough. Do I need to reset the timing or something.
Steve[/i][/b]
charlesp
Posts: 2568 Joined: Mon Mar 06, 2006 1:37 pm
Post
by charlesp » Sun Apr 01, 2007 11:24 pm
No you don't!
If you have a fat spark from the original crankshaft with a replacement flywheel then you can discount ignition as a problem. Timing is fixed by the location stud, and you simply don't need to worry about it.
If you have compression, and a spark, it must be fuel...
