How do i get the props off the reverse gearboxes?
niander
Post by niander »
How do i get the props off the reverse gearboxes?the pin seems very tight?
niander
Re: How do i get the props off the reverse gearboxes?
Post by niander »
Is it just the pin that should knock out?
cheers
RickUK
Post by RickUK »
Yep - drive the pin out with a well fitting punch (to stop the pin burring over) take the collar off, and then the whole prop assembly (prop, drive spring, and hub, at which point you will see the drive pin through the prop shaft.
Before reassembly, clean, lubricate the prop hub so that the prop is free to turn on it, and the outer collar, which should be a good but not overtight fit.
niander
Post by niander »
thanks the pin seems very tight
and dosent want to move!
