British Anzani Pilot free to a good home
Posted: Thu Jul 17, 2008 9:13 am
by newbie
I have had this little engine for about 6 months the idea was to use it as a mackerel trawling motor. When I got it home I discovered it was ceased solid with the piston actually rusted into the barrel, tried a few things to free it up but to no avail and I have now been given a 2.5 horse seagull so I've lost interest. The engine is a 1954 British Anzani Pilot 1.5hp (or at least that is what I was told) and has no fuel tank but otherwise it all seems to be there, its yours for the cost of the postage or free if you can come and pick it up from Caerphilly (near Cardiff in Wales). It seems a pity to throw a this little vintage engine in the bin fix her up, use her for spares the choice is yours, so anyone looking for a new project, here it is
Poorly Anzani Pilot for free
Posted: Tue Sep 02, 2008 5:40 pm
by Anzanipilot
Dear Newbie I have a Anzani Pilot that I am trying to restore. Your offer if it is still available is the answer to all my problems. I am sure that we can come to some arrangement regarding transport. All the best. Malcolm Rose.
Posted: Thu Sep 04, 2008 10:53 pm
by niander
Has this now gone?
Poorly Anzani Pilot
Posted: Fri Sep 05, 2008 9:27 pm
by Anzanipilot
Newbie Hi! There seems to be a little interest brewing up regarding your fine offer of a poorly Anzani for free. I could really do with this motor and hope to hear from you in the not too distant future. All the best. Malcolm Rose.
Posted: Fri Sep 05, 2008 9:34 pm
by niander
Youve already got one!...
Posted: Mon Sep 08, 2008 8:26 pm
by Anzanipilot
Hi niander you little Toad, trying to steal this motor from under my nose? If you really want it and intend to restore it, I will step back, and wish you well. It is just that my motor is in much the same state as the freebie, only worse. The flywheel is broken at the centre, the coil plate is cracked, and the crank needs regrinding and fitting with new bearings. The piston was solid in the bore but by careful surgery with a hammer and chisel, the piston is now out of the bore (in pieces), so I have a way to go. Let's hope that we get some feedback from newbie soon. All the best. Malcolm Rose.
Posted: Wed Sep 10, 2008 8:42 am
by RickUK
Malcolm - I should have a Pilot you can have which I think will yield the parts you need.
ingintions are interchangeable as a set, but do you happen to know which ignition yours has? A lot of the earlier ones had Miller ignition, whereas later ones went to Wipac. If Wipac, the name is cast into the top of the flywheel. Motors up to and including the mark 3 had Amal carbs - later ones a Zenith carb. Worth doing - I think they are underrated little outboards. Rick.
Posted: Thu Sep 11, 2008 5:53 pm
by Anzanipilot
Rick, great to hear from somebody with some knowledge. The motor that I have has an Amal carb but I can find no sign of a Wipac stamp on the flywheel, so maybe it has been modified in the past. Perhaps we can come to some arrangement regarding your motor? All the best. Malcolm.
Posted: Fri Sep 12, 2008 9:03 am
by RickUK
Hello Again Malcolm - it sounds as though your motor is correct - just somewhere pre-Mark 4.
Doesn't make a lot of difference, but does your motor have an aluminium tube or a cast drive leg?
Whereabouts in the country are you? Be much easier if we can meet up and have a sort out.
Rick.
Posted: Sun Sep 14, 2008 8:19 pm
by Anzanipilot
Hi Rick, thank you for coming back to me. My motor has a cast aluminium leg running down to the prop if that is the one you have in mind. As to meeting up, it sounds a great idea but you live in Huntingdon and I live on the Cornwall/Devon border, a tad too far away. All the best. Malcolm.
Posted: Tue Sep 16, 2008 8:16 pm
by Anzanipilot
Rick, I hope that you have not given up on me. I still need those parts and although we may live a fair distance apart I feel sure that we can come to some arrangement.
As for you niander you seem to have gone very quiet and yet maybe you have some insight/knowledge that you could throw into the pot. Indeed a line from him that started this would be most welcome. I look forward to hearing from you Rick. All the best. Malcolm.
Posted: Tue Sep 16, 2008 9:46 pm
by niander
Sorry but i cannot impart any insight/knowledge on this post i also havent heard from this guy!
Posted: Wed Sep 17, 2008 8:47 am
by RickUK
Hi Malcolm - was getting my wired crossed last week so lost track - must be getting old! - still here - what do you need again? Rick.
Posted: Wed Sep 17, 2008 4:21 pm
by RickUK
Malcolm - just realised what my problem is - it's all you guys using aliases!
Anyway, let me know what you need, I have some things from parts to a complete engine, so I should be able to help.
Might be better to pm me, so at least I will be sure to see your message. Rick.
