Hi,
not so much for sale, more fed up with looking at it.
Originally WSPCL I773G2.
Bad bit's
blue steal tank, no tap, fuel line, or cap
no ht lead, cap or plug
rusted out block which has been welded and a plate screwed on
old villiers stator plate and flywheel, not fitted as no screw for stator, not sure the coil is good or bad
wrong bottom end now fitted, 4 blade prop and small gearbox, no spring.
broken mounting bracket with no washers
Good bits
did run before I started robbing it of parts
has compression
good throttle cable
avarage chrome on drive tube
have photos and can email them.
Would like two good spark plugs, two HT leads and a drive spring in exchange. Collect from Portsmouth England only
regards
Phil
it sounds exactly what i'm after, if all goes to plan, i haven't got the bits you want, but will get them or would be happy to reach a deal if you would send photos i'd be glad, you could phone me on 07979856467 or email me at; redclyffeconstruction?vodafone.net ( i've put ? instead of @ to avoid spam) do you know what the box is from? hope to hear from you soon, ta, chris
