A little gift
Posted: Mon Dec 09, 2019 8:57 pm
by JERSEYMAN
Here’s a little Christmas gift for those with an interest, I picked it up recently and thought why not share it.
Re: A little gift
Posted: Mon Dec 09, 2019 8:58 pm
by JERSEYMAN
And a few more, happy reading.
Re: A little gift
Posted: Mon Dec 09, 2019 9:25 pm
by cookie1
Excellent ! Thanks for sharing
I wonder what the mk 1 and 2 were ?
Re: A little gift
Posted: Mon Dec 09, 2019 10:07 pm
by tambikeboy
Re: A little gift
Posted: Tue Dec 10, 2019 1:47 am
by Sandro_Picchio
Thank you very much.
Merry Christmas.
Sandro
Re: A little gift
Posted: Fri Dec 13, 2019 8:27 am
by AusAnzani
Awesome. Thanks for sharing!
Merry Christmas.
Re: A little gift
Posted: Sat Feb 08, 2020 7:32 am
by Raya
Great piece of history.
On page 2, in the list of spares, it specifies the spark plug as a Sintox C3. This is a Lodge plug. Did the SD's have Lodge from the factory or was this just the army spec for the replacement? I can't recall this plug being mentioned in any of the posts I've read.
Re: A little gift
Posted: Sun Feb 09, 2020 11:17 pm
by geofflena
Nice old read that -
1 and 1/4 pints to the gallon is a very heavy mix ? ( thats over 6:1 )
Also - did SD's have a choke flap ? - as there is no mention of using one on starting - cold or hot.
I like the advice tip ( adjust throttle screw until it ticks over etc ) and stop it by choking.
Are side mounts common - never seen one or seen one for sale ?
Good basic advice there also for problem starting a flooded 2 stroke.
I did invent a little thing that kept a throttle lever at tickover but flipped off to stop it - but I lost my drawing and cannot remember what it was. I will have to re-invent it
Re: A little gift
Posted: Mon Feb 10, 2020 12:11 am
No choke just a 2" trumpet, chromed or bare brass.
There are pics on here of wartime side mount brackets but they were designed for specific military boats so need modification to work on modern gunnel & transom styles.
Remember there were no 2-stroke oils available pre 1950, apart from racing castor oil so a bit of extra 30 weight motor oil was probably playing safe!
Re: A little gift
Posted: Mon Feb 10, 2020 7:15 pm
by JERSEYMAN
One of the several types of wartime side mounts and mounting stub
Re: A little gift
Posted: Mon Feb 10, 2020 10:22 pm
Thanks Rennie, this is an example of a wartime bracket that has been modified for use on a transom, but has a side mount thrust block, but would work on a conventional gunnel.
Hugo if you see this can you post a pic of of an original one.
Re: A little gift
Posted: Tue Feb 11, 2020 11:53 am
Here’s a another photo of a wartime side mount, only a few of these known to exist. Also a photo of a brass inlet trumpet, fitted to a rare brass carb body.
