New to the board and I have a BMB Swordfish
Posted: Fri Aug 31, 2018 10:49 am
Good morning all.
I found this forum while searching for information about the Britannia Swordfish.
The motor was passed to me a couple of years ago by a friend who had cleared the shed of a deceased gentleman acquaintance.
I have been bringing old motorcycles and bicycles back to life previously, so restoring an outboard motor is all new to me.
There's the excuses declared for when I inevitably ask dumb questions.
I've no idea what to do with this engine when restored as I don't possess a vessel to clamp it to
The motor is complete apart from the original tiller arm missing.
I believe it to be a MK 1, based on the carburettor top (referenced from the user manual)
The carburettor leaked badly. Subsequent investigation revealed a stripped thread in the bottom of the carb body. 5/8 UNEF apparently (0.625 x 24tpi)
I have a lathe, so I intend to insert a newly threaded sleeve into the carb body. I sourced a 5/8 UNEF tap from Ebay.
The fuel tank is badly dented and probably leaks.
I had the engine running briefly before consigning it to the projects awaiting shelf.
Any comments would be welcomed. Any guess as to age? Any suggestions for restoring the tank?
Photos attached, hopefully
