This may sound stupid, but how do I tighten the top dome nut on top of the flywheel, when the flywheel and crankshaft keep turning?
Donald A
And what is the torque no for this or is it just good old fashioned FT........
Tightening top nut
Re: Tightening top nut
As long as the thread is clean and not all beaten up, I just hold the flywheel put a ring spanner on the nut and give the spanner a tap with a hammer to nip it just a little.
In the book of words Chapter 5 page 65 #4
"install dome nut and tighten with wrench.
After dome nut has been tightened snugly, strike the wrench smarty with a hammer and set the nut securely."
Thanks for that - what do you mean by book of words?!
D
D
British Seagull Outboard Workshop Manual
Tighten it till its loose then back it off a quarter turn....
Huh?bercan wrote:Tighten it till its loose then back it off a quarter turn....
Thanks for that Hugz - you wrote what I was thinking.....surely this is the tightest nut on the engine?
Donald A
Donald A
