Electronic ign flywheel nut
I have removed these before using a bodged up pulley holding tool made out of a garden hoe but .....How are you actually meant to slacken / tighten the flywheel nut on an electronic given you can't hold the flywheel from turning as it has a cover and you can't take the cover off without removing the starter pulley .... which means removing the nut .....?
Re: Electronic ign flywheel nut
Put it in gear & put your foot on the prop!
Starter rope might hold it.
I usually Loctite the starter cup spacer both ends, but not the threads or shaft.
Thanks, I will give that a go and thanks for the Loctite spacer tip.
