does anyone know if the following would work on an amal 420/A/2 carb as fitted standard on the 170?
http://r.ebay.com/tlEPm8
Thanks!
twist grip question
- seagull101
Re: twist grip question
Yes it should (if the cable is long enough) fit all seagull carbs!
Jacob
Jacob
Agreed.
Cable length is the critical point here, not the actual control mechanism.
Even a villiers.
- seagull101
I have just been informed that the cable definitely wont fit and that the tiller itself wont bolt onto a 170,
The throttle mechanism itself will work.
Jacob
Jacob
