Model 55 no spark issue
Posted: Mon Jul 10, 2017 4:45 am
G'day all
Recently was offered an EFPC (Model 55) 40 Series from approx Jan'84.
As I already had a GFPC (same same but with Bing carb) I thought it would yield spares if nothing else.
So in trying to get it going I have:
- cleaned the plug (then replaced it with new)
- cleaned the tank and put in fresh 25:1
- cleaned carb and checked slide operation
Didn't get even a hint of firing, so pulled the plug, attached a new plug and grounded it to find (as far as I can see) zero spark.
There is an issue with the plastic casing on the plug HT lead being split, and some evidence of corrosion on the wire, so that may be all it is, but I dunno.....
Looking at the brown box on the base plate I can't see any markings on it, so can someone who knows about these things tell me if it is the correct CDI unit for a Model 55 - think it's meant to be a Wipac 3...?
And is it it possible to replace the HT lead on its own? It seems to be firmly fixed and not easy to remove, so am not sure how it would come off..?
And what's that extra (small) wire coming out of the other side of the CDI that seems to terminate in a red female plug fitting. Could that be meant to go to a kill switch..?? [Which I wasn't aware any Seagull's had, so is it an "aftermarket" CDI unit or what's the story..?]
Any ideas?
Mark
Any ideas?
Mark
