WTB - WICO PACY Flywheel Anzani Uni-twin or similar
Post your wanted adds here
Hi guys,
I am in need of a WICO PACY flywheel or magneto to suit an Anzani Uni-twin outboard. The same magneto was used in a number of smaller 2 cylinder engines (including the Aussie made Riptide Sportsman – and yes with taper and threads same as Anzani) hence I thought I’d post some photos also for your reference.
One on left is from the Riptide Sportsman, the one on the right is from an Anzzani Uni-twin. Castings are slightly different (presumably build year) but otherwise the same.
From the Sportsman - more detail.
From the Unit-twin - as above however casting number is P2474, as against P2474M. The Anzani flywheel also only has one hole to access the points.
External dimensions
Look forward to hearing from anyone that may have a spare flywheel of the above description. Needless to say, I am prepared to pay for the part and all postage costs.
Thanks & regards,
Re: WTB - WICO PACY Flywheel Anzani Uni-twin or similar
Just thought I'd give this a bump to bring it back up to the top.
Any help would be much appreciated.
Thanks & regards,
