Silver century running problem
IanLynx
Post by IanLynx »
I have a silver century with a two jet amal carb on it. It has the 25:1 conversion jet fitted as supplied by Seagull.
1 It is a pain to start - usually needing a sniff of WD 40 in the intake before running.
2 It will then run fine but only with the choke flap in place - take the choke off and it will stop - it will run on full throttle but very badly and stops as soon as you reduce throttle.
I have cleaned the tank - set the points to 15 thou and 20 thou. Changed the gap on the plug from 20 to 25 thou. Changed the plug from the 8 com fitted to the Bosch plug that works fine in my older 102. Had the carb off - jets out - soaked in cellulose thinners, blown through. I've even put the 50 power jet in and tried 10;1 fuel. All with no change.
Has anyone any ideas as I seem to have run out?
Ian
Vic
Post by Vic »
It shows the symptoms of a (partially) blocked jet despite your efforts. A solvent like cellulose thinner will not shift everything. You may have to cautiously push something through. I use soft copper wire (fuse wire)
IanLynx
Post by IanLynx »
thanks for that Vic - I'll give it a go and post the result later
Ian
niander
Post by niander »
hold it up to the light if the jets are clear you'll see it!
i have this fantastic 240v very powerful air pump[for blowing up tender]
its like compressed air...sorted
Vic
Post by Vic »
You'll see the light through it if it is partially blocked.!
I spent ages trying to get an old Volvo Penta 51 that had had some water in the carb to run properly I could see through the (slow running) jet and could blow through it but it was not until I pushed some thin soft wire through it that I got it properly clear. Then it ran as sweet as a nut.
IanLynx
Post by IanLynx »
Right then - here is the report
1 Removed carb
2 stripped carb (again)
3 looked through jet and I can see light
4 pushed COPPER wire through jet (I was always told not to do that when I first started work on engines)
5 Reassembled everything
6 Put engine in test tank (aren't the council good to give us all wheelie test tanks!)
7 Turned on fuel, closed choke, full throttle pulled cord - nothing
8 Repeat 7 - nothing
9 Changed to half throttle - pulled cord - and its a runner!
10 opened choke - and its still a runner!
11 celebrated with a well deserved cup of tea at the computer to reply
Thanks Vic.
So, even if you can see through the jet try an extra clean with copper wire
Vic
Post by Vic »
I use copper wire because it is unlikely to damage a brass jet. Even so i would not want to do it on a regular basis. Never use a steel wire thats the main point I think.
Anyway pleased to hear its now running.
CatiGull
Post by CatiGull »
Another old 'Gull saved - John - you will have to start a counter on the Main Page someday - another task for the webmaster.... :lol:
Stephen
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
