Flywheel base removal
Griffin71
Post by Griffin71 »
Does the flywheel base lift straight off on a 40?
Im a bit concerned about pulling or hammering it as alloy can be brittle, any suggestions? :cry:
Qualified Cable tie Technician.
Re: Flywheel base removal
Yes the stator plate lifts straight off, it has a securing screw underneath, but that's about it, they are not normally problematic.
Just my two penneth here.
Sometimes i've found by removing the securing screw it should in theory just lift off. This isn't always the case. If your unlucky enough to have a baseplate that has some corrosion around the top crankcase half it will put up a fight. If this is the case with yours then what i do in this instance is to strip down as much as possible all of the crankcase so you're left with the baseplate and top crankcase half together. I then use a hydraulic press (carefully) to push out the crankcase half from the baseplate. No fuss, easy as you like, no distortion and best of all you get to keep the skin on your knuckles. :P
Griffin71
Post by Griffin71 »
I think this has corrosion:roll:
I have left it to to the gearing, getting the lock screw out was really hard a lot of white corrosion on the thread. :cry:
Unless you've got one already, go out and get yourself a plumbers type blowtorch.
Very useful for a whole host of jobs on most seagulls.
