Hello,Nice to be on the forum! I have a TC102 with a 2 jet carb that is corroding on the body threading. As mentioned in John's identifier page these engines also used the 416. But are there any other carbs that I could use?
Regards, BJ
102 carbs
Re: 102 carbs
SOS offer an exchange service for a repaired Amal twin jet carb body. Well worth doing.
barnicaljohn67
Re: 102 carbs
Many thanks, BJ
Re: 102 carbs
Plenty of amal 46n carbs around if you look. Plenty of rubbish too. Most 46n carbs tend to suffer with corrosion around the fuel banjo area, very common place for them so be very careful with any replacement carb. Treat with care. Oyster's right, John offers a refurb service for these carbs now. They should last quite well.
Some of us on here prefer the original look of these 102's, where others are purely after that something works well. The later 400 series Amal are a good carb, but in my opinion better suited to a more modern version of a seagull. I'd try and stick with the original set-up using a 46n. Much simpler with less to go wrong.
But that's just me...
Oh, and welcome aboard!
barnicaljohn67
Re: 102 carbs
Many thanks, I'm off to the jumble today so I'll look around. Let you know in time how things go. Regards BJ
