What Gulls Had Twist Grip Throttles
Re: What Gulls Had Twist Grip Throttles
Later engines, late 70-80s ish onwards.
That part looks like it is the same Doherty unit as fitted to british motorcycles. New pattern versions are available to fit 7/8th bars.
Some seem to prefer them to the standard lever as they can be adjusted to hold any throttle position, the same as the standard lever.
I don't think Seagull produced them, as it looks to be just a standard British twist grip, black grips with a 90% cable outlet are seen on later QB motors.
I have had old Seagull's with them fitted on in the post and just remove them, you normally see it fitted in conjunction with that horrible add on recoil starter.
The twist grip throttles supplied by Seagull were manufactured by Amal & were fitted as an optional extra by Seagull from about 1978 onwards, though could be supplied to the end used, with the correct cable for just about every carb fitted by Seagull.
chaldon3
Post by chaldon3 »
i am glad you have mentioned the recoil starter, my fp has one and i have been thinking of removing it. i hate it,
now i am not on my own it is coming off. :lol:
the animals are winding me up
Never needed to ever buy one, they seem to come free with a Seagulls. :lol:
The only problem with using the motor cycle type twist grips is that the cable exits the unit at 90 degrees to the tiller arm, rather than parallel like the Seagull ones, requiring a longer custom made cable, that has to have an untidy routing back up & over the top of the cylinder to the carb.
No problem.
http://www.ebay.co.uk/itm/NEW-ADJUSTABL ... i37wm9PYhg
If you don't know how to fix things you shouldn't own a seagull. :lol:
flyguy
Post by flyguy »
Collector Inspector wrote:Edumacate me if you would.....
http://www.ebay.co.uk/itm/BRITISH-SEAGU ... 3641.l6368
I see he has a Seagull for sale too
http://www.ebay.co.uk/itm/BRITISH-SEAGU ... SwA3tXokQ-
tambikerboy
Post by tambikerboy »
£575 wow pickle my piles in polecats p # ss that's big money..... :shock:
BUT I CAN NOT KEEP THEM ALL
At that price he might well do.. :P
AusOB_Collector
Post by AusOB_Collector »
Ohhh that recoil starter is ugly!
To my eyes it looks a bit younger than 1949?...
BP
Member SOS, AOMCI,
The gearbox looks older than the pump housing/exhaust, big eared fuel cap is a late one, I think it's a mixed bag of parts that makes up this motor.
Yep.
Bits of this, and bits of that.
Drive tube is much much later (it's a shanked type) which is why the chrome is still nice.
Clutch lever is the wrong type for this age of motor
What the hell is up with the tiller???? Uber long or what!!!!!
Cant really get a good look at the gearbox but i suspect it has slots and not holes.
Some of the fixtures and fittings look to have been "updated" as already mentioned.
But let's be fair to the guy, it's not a bad effort is it.
It might not sell at that price though, tis a bit steep for a bitsa. A reasonably good looking bitsa at that.
I shall try and communicate with the seller and see if he's one of us :P
