Then you will need to replace the now sheared bolt that stops the fuel tap from falling to bits.
That little screw is the same as the terminal screws in british 13amp plugs.
This was a tip from "pooroldguy" who has a load of sensible tips on youtube for seagulls.
He looks much like I might be in twenty years or so.
