102 barge pusher.?
102 barge pusher.?
http://www.ebay.co.uk/itm/outboard-engi ... Swv~xXDmU2
i like the look of this but lack the knowledge to identify.
me thinks 102 barge pusher. due to fuel tank,cylinder head, and prop.
just up the road from me. what advice can you offer my friends. regards garry.
the animals are winding me up
Re: 102 barge pusher.?
Its listed as SD.5035.L3, so what's that around 1944 or something.
I did spot this one, nice, but too for away.
Microdots again
Looks like a good honest engine. SD model with incorrect later prop. The filler cap is a later screw in type too, but its a steel tank? Well worth bidding on in my view.
I'm only looking from my phone so not that clear. I think there might be more amiss at the lower end than just a prop. I good starting point to bring back to order.
Addit: Clutch lever? Original tank straps!
Think there is more than a prop amiss here. If this is an SD, shouldn't the water pump housing be the straight out the back exhaust? Probably why the wrong prop is on there. Carb appears to have a choke lever, thought SD's did not have a choke. Missing HT lead. Wrong transom bracket assembly, cobbled together fuel line. Assume tank is from a newer engine due to screw down cap, which is also a newer variant.
Do not get me wrong, as I would still love to have especially at the current GBP10 price, but looks like a lot need to get back to original, if that is your thing. If you do not care about originality, then with a little clean up,I am sure this will run just fine
I've concluded it is the correct tank but has a later cap jammed in! Lots of good stuff there.
It is very much something that has been kept useable over its life.
Lots incorrect but shows some history.
Interesting if compression, spark......generally runs aye.
many thanks all. owner sent serial number. check on john's id page.
942 to 1946
Model Name Wartime 102
Gearbox Clutch 2.5:1
Prop 10 x 8 1/2 (Two-blade, raked)
Fuel Mix Ratio
Cylinder Style Short Water Jacket
HP 4
Gear Oil SAE or EP 140
try my hand at winning this fine gull. garry.
942 to 1946
Fuel Mix Ratio
HP 4
Yes, the exhaust is a cut down version of a later "Sub ejector" lower housing. Missed that first time around.. they can be obtained, I have a couple spare.
thanks for your input oyster if i get it at the right price i would like to return to as close to original;
hugz. i noticed the dots and wondered if the owner had made a mistake with id number i have read previous posts on the decimals.
more than a coincidence that they turn up on a few gulls. love a mystery. thanks all. garry
ps any one have the correct two blade prop. the two blade prop looks so, well classy. if that make sense.
Props can usually be found
Let me know if you need a lower housing, I have a couple which need a little attention.
This one seems honest, if it is close it might be worth going for a quick look. Tanks can corrode, and have a good look at the cylinder to check for corrosion. Assume the coil is duff, and factor the cost of a new one (£65ish) If the tank has been bodged I think bayonet filler necks can still be found. Charles will know.
All in all nice projects the SDs.
One think I like about the copper top SD's is that they have the potential to go up in price as they may well be sought after not only by Seagull Collectors but also by WW11 collectors. And as such it is worth spending on their restoration over and above their market value. Finding a bayonet tank cap will take you a little while but there are moves a foot to have some produced. The straight exhaust is common to early A series so can be had. Fuel line can be made. As previously mentioned check if short water jacket is sound. I've put together far more incomplete SD's than that one!
I hope you don't get gazumped by a fellow seaguller for bringing it to our attention. I still say we should have a members only section on this forum so motors like this can be discussed away from the public eye.
Question about the three blade prop in this engine?
What seagulls should have this propeller? As i haven't see a 102 with a 3 blade prop.
