paint removal
paint removal
Hi, What is the best way of stripping the paint of a brass tank? I'm leaning towards sandblasting but have concerns it might pitt the final finish... any ideas?
Cheers Hugo.
Forums are for entertainment and information.
I always use paint stripper. I'm fairly confident that blasting would do the trick - as well as provide a good key for the primer - but paint stripper is gentler on the brass.
Even if it does no good at all to the environment..
Hi, I do have some concerns that the acid might affect the finish of the brass, ie discolouring, as I prefer to have a polished brass look. Might do a bit on the underside first.
Thanks.
twostrokenut
Post by twostrokenut »
Hi , Bead blasting would leave you a smoother type of finish compared to grit , grit does tend to leave a good key for paint adhesion , but if a polished finish is what you require , then bead is that much kinder.
Andy.
Yep, beadblasting sounds the go. Now to find someone that does it.
Thanks
CatiGull
Post by CatiGull »
You could use a methylene chloride based stripper which is not acidic and should be brass-safe.
Stephen
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
Vic
Post by Vic »
Methylene dichloride AKA dichloromethane. I'm not a aware that paint strippers are ever acidic. Caustic soda will attack most paints and varnish.
