wipac 2 base plate and flywheel
kev shep
Post by kev shep »
just replaced my centry villiers system to wipac set points to 20 though when i pull start cord to start just back fire but good spark at plug any idears ?
Re: wipac 2 base plate and flywheel
How have you set the timing?
supersaint61
Post by supersaint61 »
is your woodruff key in place
kev shep
Post by kev shep »
woodruff key is in place brought piston to T.D.C and set points to 18 thou
Where did those instructions come from Kev?
Didn't your crankcase have the locking screw dimple?
kev shep
Post by kev shep »
yes and screw base plate located
Do you know if the crankshaft has been replaced & has the motor ever run properly during your ownership?
Is it a forty model or a century 102 model?
With the tank furthest away from you, looking at the top of the motor,the ht outlet from baseplate should be at 8.00 o,clock for a forty model, or four o'clock for the century/102 models.
Sounds like your timing is out if it backfires, not sure why you are setting the points at T.D.C, set the points when they are fully open,just rotate the flywheel untill you see them open fully, then set with feeler gauge.
