I tried to make these Sea Gulls work on my fishing boat, but, in reality I need a short shaft motor.
So, that being said, I'm gonna try to sell these and see if I can pick up a short shaft S.G..
First one is a 1969 Century 4.0 HP long shaft motor.
Villers carb.
Cleaned carb, re set points, added a brass tube on the water outlet to draw water at low RPM, works great!
It'll start every time 2-3 pulls.
Spare parts kit, spare prop, s/plugs.
Next one is a 1975 Silver Century 4.5 long shaft
416 carb
Cleaned carb, reset points, a brass tube to pull water at low rpm
I just re-rung it, (old ones were perfect), clean the water passages, new head bolts
I have what is left of a gasket rebuild kit, (impelar lower unit gasket).
I have the lower unit screws, a spare carb, spark plugs.
This one is all repainted and looks good.
I have the shop manual and spares book you can copy for both motors if you buy one or you can have to books if you buy both!
joe57prep@gmail.com
Make me a offer on each or the both.
I'm located in Olyphant Pa. USA
						2 Century for sale
