air cooled outboard question
Do you need to run outboard 2 stroke oil for an air cooled outboard
- AusOB_Collector
Re: air cooled outboard question
Hello Chris
I would always recommend using a good outboard oil when running any type of outboard - but for an air cooled one don't use an oil with a TCW grading - specifically for water cooled engines so works with a different temperature range to oils purposely made for air cooled engines.
Hope this helped
BP
Hope this helped
BP
Member SOS, AOMCI,
Member SOS, AOMCI,
thank you that is good advice
Two Good Ones.
Choice #1 Stihl HP
Choice #2 Castrol Activ 2T
Choice #1 Stihl HP
