Running problem on 40-plus
Geertje
Post by Geertje »
Hello All,
I have a running problem on a 40+ that is puzzling me.
Sometimes after a period of normal operation the engine begins to sound as if it is struggling and revs drop significantly - sometimes stabilising at a lower speed, sometimes continuing to head downwards as if the motor is to stop.
What I have found is that comnpletely obstructing the air inlet with the tip of a finger for a fraction of a second and then releasing it causes - after the momentary downwards blip - the revs to immediately rise again to the normal level and the engine to continue running at full power.
Any thoughts about what's going on?
Dutch Barge "Geertje"
Vic
Post by Vic »
I think I would start by cleaning the carb, the jet and the foat chamber, and the fuel tank.
If you are filling it from a can check that for contamination, esp water.
Katomi
Post by Katomi »
One more thing to look at is how do you mix your petrol and oil. I was out yesterday and someone had the same problem.. He was putting oil in the tank then adding petrol. the oil was sitting in the fuel pipe .
Hope this of some help
Stephen
CatiGull
Post by CatiGull »
Classic water contaminated fuel running behaviour...
Stephen
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
