Forty Plus prop
Forty Plus prop
Afternoon, I will be using my new/old 1976 Forty Plus on my 3 meter Inflatable boat, now this may be daft question but if I was to use a smaller prop from a 40 minus would it give the boat more speed?
Re: Forty Plus prop
More revs but I doubt more speed. The 40 minus prop is pretty small if I remember correctly
Re: Forty Plus prop
Yes, its quite a bit smaller.Michael wrote:More revs but I doubt more speed. The 40 minus prop is pretty small if I remember correctly
Re: Forty Plus prop
what are you up to Rob?
Re: Forty Plus prop
Bear in mind the differing gearbox fitted to 40 plus and forty minus engines. the forty plus has a larger prop running at lower gearbox RPM. fit the smaller prop to the forty plus and you will get less thrust and a tendency to over rev. So a slower boat and a screaming engine, revving beyond its limits.
Re: Forty Plus prop
Hi Jon,headdownarseup wrote:what are you up to Rob?
Just thinking aloud, had what i thought would be the answer confirmed
Hope your new project is going well.
Re: Forty Plus prop
Thats what I thought, stick with the origional. Many thanks.Oyster 49 wrote:Bear in mind the differing gearbox fitted to 40 plus and forty minus engines. the forty plus has a larger prop running at lower gearbox RPM. fit the smaller prop to the forty plus and you will get less thrust and a tendency to over rev. So a slower boat and a screaming engine, revving beyond its limits.
