Hi guys i have 2 seagulls with numbers
niander
Post by niander »
Hi guys i have 2 seagulls with numbers they need parts inc carbs
LS26167L
AD13400L
i notice they have 2 different size tubes for the carbs
are there only 2 different sizes of carbs
anyways could someone tell me which type carbs i need please
CHEERS
allymoss
seagulls no.s
Post by allymoss »
Hi,
There are 4 main types of carb
villiers (10:1 or 25:1) round air intake
Bing (25:1) square air intake
Amal 2 jet (10:1 or 25:1) 2 tubes, joined at the bottom
Amal 416 (25:1) Air intake is a cowl, says amal 416 on it!
The LS I think needs a villiers (common, cheap to get on ebay)
The AD I think needs an Amal 2 jet (quite rare due to threads shearing easily)
Someone please confirm, not entirely sure.
Alistair Moss
Mossesgulls
http://www.mossesgulls.co.uk
Alistair Moss
Hi Alistair you are not plastering adverts on here! you get a mention on the links page, don't push it!
niander
Re: seagulls no.s
Post by niander »
Hi by tubes i mean where they connect to cylinder block.
allymoss
tubes
Post by allymoss »
Hi,
Yeah, there are different sizes. Villiers is small! Not sure of exact diameters. Amal 416 carbs have plastic inserts which can change the size of its hole.
Best to ask Charles P or Charles UK or John
Alistair Moss
Ally is quite right - there are four, or at least there are four after World War Two...
The Villiers is the one for the LS. This motor is the original version of the Forty Plus.
The AD - a 102 - used the same 2 jet Amal carb that Seagull favoured for decades on 102s and Silver Centuries. The one on your example would have had the cowl without a choke. I have no idea why!
The later Amal is a good carb, and will fit, but it would be a shame to put a modern carb on a mid 1940's motor.
niander
Post by niander »
Ok thanks guys
