Got a large seagull alluminium transom bracket and it has Solid alluminium c clamps with no markings on the c clamps
It does has bent bronze thumb screws
Im wondering if these c clamps are seagull or aftermarket?
Solid alluminium c clamps ?
- Niander101
Re: Solid alluminium c clamps ?
It did look a little different from the standard transom, but though that maybe the clamps had been added to the transom from a damaged or older transom, as the bracket looks to be a lot later than the clamps.
You may have to put up a picture for the ones that didn't see them, if its the ones off Fleabay, was it something like £15 postage, if I remember rightly.
- Niander101
Yes they are the ones
exactly the same
thats good then
and it is the one off fleebay
off good old Bob the seagull....
exactly the same
thats good then
