I read in MBM a few years ago that a company was planning on producing a diesel outboard line up. I haven't heard anything since
Has any one ever produced a diesel outboard motor before... I'm sure I've heard of a Volvo Diesel motor but the 'expert' in the marina next door said its a myth.
Neal
Diesel outboards
Diesel outboards
Bilge pumps? Nothing shifts water faster than a scared man with a bucket!
- 1650bullet
Re: Diesel outboards
As Mr Hugz has posted up. That answers your question. But there biggest let down is there wieght. There just under 4 times as heavy as a 2 stroke engine around the same Hp. Thats why there not a big seller. To Heavy, and to expensive to buy.
Google- amarc diesel you tube. Warning you need a high speed connection unless you don't mind downloading in snippets.
It takes a minute to warm up, then you see how it pushes the boat, I'll take a Seagull any day!
- 1650bullet
Here is another short 27 Second clip of a Yanmar Diesel outboad working.
http://youtu.be/1Pu4RJmevrQ
Cheers... my internet connection is a bit hit'n'miss lately and google doesn't work, I may have wipe and re-install my computer
I was wondering about alternative main engines for my 18ft Dory, I have to bond a new transom in and wondered about beefing it up to take a bigger motor... I'll stick with the Seagull sounds much nicer
The fuel line from the boat to the diesel motor, is it a high pressure feed?
Neal
Neal
- 1650bullet
Im think you will find its a normal fuel line feed from the remote fuel tank, to the fuel filters, but then its all high pressure from the injector pump and fuel rail.
