Leaky fuel tank cap
Posted: Mon Apr 23, 2012 10:06 am
by dartmoor
Hi, I have two of the plastic type fuel caps with the metal breather screw. Both leak from the breather screw when laid down on their side, even though the screw is tight. What is the cure for this? It's an annoying problem!
Re: Leaky fuel tank cap
Posted: Mon Apr 23, 2012 10:36 am
A new set of washers from John should do the trick, but dismantle the cap first to check there are no cracks.
