Leaky fuel tank cap
dartmoor
Leaky fuel tank cap
Post by dartmoor »
Hi, I have two of the plastic type fuel caps with the metal breather screw. Both leak from the breather screw when laid down on their side, even though the screw is tight. What is the cure for this? It's an annoying problem!
Re: Leaky fuel tank cap
A new set of washers from John should do the trick, but dismantle the cap first to check there are no cracks.
