CDI Module Kit
CDI Module Kit
This is an article fron Silicon Chip here in Aus May 2008. Its a CDI module. Which is avalable from Jaycar Electronics, KC5466 $21-95. I have built several of them & used them on small engines to replace faulty CDIs that were either too expensive or just not avalable. There is only a few parts invoved, if its a multi cyl engine then you need one for each cylinder.
Re: CDI Module Kit
Oops one wrong page in the previous lot.
Re: CDI Module Kit
Daryl
Thanks for posting the 'Silicon Chip' pages
Up til now, I've been reluctant to buy one of these kits without the supporting article
What's your preferred potting compound? I use epiglass HT9000 but it's a bit expensive.
Rex NZ
Rex NZ
Re: CDI Module Kit
Looks good Daryl, I am looking for similar kit in the UK, but as yet no luck.
Re: CDI Module Kit
Hi Rex. Ordinary Fibreglass resin should be ok, I have been known to use Roof & gutter neutral cure silicone.
Re: CDI Module Kit
Do you think this would work well as replacement for dead Seagull CDI?
Chicken
Chicken
33 RACING NZ
Re: CDI Module Kit
Not sure since i dont have a Seagull with a CDI, & havent seen a circuit of how one is actualy wired up. After looking at a few pictures of a Seagull CDI, It doesnt look like its suitable.
