okay so I did a dumb thing. I'm attempting to put my
throttle back together on a Featherweight. I have a big screw,
a spring, metal washer with square hole, and rubber washer.
I can't find a parts explosion to tell me where the two washers go
and in what order. Can anyone help?
Throttle
Hello there, sadly I have not put a pic of the lever on the site yet, I thought I had, but the one off of the FAQ page does not show all the parts.
The moving part of the lever goes onto the base, with the cable attached, then there should be a fibre washer, then a metal one, then the spring, held down with the screw!
Hope that helps,
SOS
Hope that helps,
SOS
CatiGull
Since John's away Ill step up the plate ...
if you email me your model Ill pull up the diagram from my book and email it to you if you are still stuck..
Catigale (at) nycap (dot) rr (dot) com is best email
CatiGull
CatiGull
Stephen
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
Awenke Yacht Club
New Baltimore NY
S/V Catigale
Macgregor 26X
Island 17 Sloop
