various seagulls in ipswich/southwold
james
Post by james »
Alas I haven’t had a boat to use these on for a few years so they may as well be off to a better home.
3 seagulls in various stages of disrepair
I have not used any of these since 2008 (I think) all are complete and have all mounting brackets & controls etc.
1968 century.
Started and ran fine but wouldn’t pump water, so I have never used it. One of the head bolts has snapped when trying to solve this problem so I didn’t do anything further. Currently has the leg removed but I believe it is all there.
1967 forty plus mk2 non-clutch,
New bevel gear, rotor, spring, pins & gearbox bolts & gaskets installed (purchased from SOS) in 2006 and only 1-2 hours use since. Should run ok, this was my favourite and the best.
1976 forty plus with clutch, when last used it ran ok for first few minutes but then would die, carb problem suspected.
Seagull carrying handle.
if anyone in the area would like a look or wants to make me an offer please get in touch, at the moment the century is in Ipswich and the others in Walberswick, near Southwold, however I intend to bring this back to Ipswich soon, I will sort out a few photos then.
PM me or give me a call on:
zero seven seven one seven eight three two nine zero eight.
james
Re: various seagulls in ipswich/southwold
Post by james »
the 1968 centrury is free to anyone who can collect it from martlesham heath, ipswich ip5
phone number as above
Stylo Seagull
Post by Stylo Seagull »
Thank you james.
Good to meet you today.
Two of the three running now
Will get the other forty running sometime this week.
Cheers!
FP416G2
james
Post by james »
These are all sold now.
Hope you enjoy them Jon and glad to see you got them running so quickly.
