Kingfisher mounting height
johnyjf
Post by johnyjf »
Can some one tell me if the measurement in the handbook quoted for the transom height of a boat is intended to be from the underside of the engine's clamps just where they contact the mounting board please. Or if it is elsewhere then where exactly?
Thanks and Regards
Re: Kingfisher mounting height
http://www.saving-old-seagulls.co.uk/im ... b%2006.jpg
Top of transom to waterline
15" Standard Shaft
20" Long Shaft
johnyjf
Post by johnyjf »
Thanks for reply, I assume that if I have a bracket mounted on my transom then the measurement id from the top of the bracket?
Vic
Post by Vic »
Yes
It is what you said "from the underside of the engine's clamps just where they contact the mounting board please"
