I am about to put my head back on my silver century plus, annealed the gasket, now was wondering if the head bolts should have a sealant since they go into the water jacket.
at a minimum I will use an marine anti seize. I do remembet my brother always using a silcone sealant on his big V8 engine rebuilds when ever the head bolts went into a water jacket and thought the same principle would apply. My lame Clymer book says nothing about this!
Paul
Do head Bolts require a sealant?
Paul G
Kirkland, Washington USA
Re: Do head Bolts require a sealant?
Paul:
The Classic Seagull Book by Meyers recommends using a mixture of waterproof grease and anti-seize lubricant (FWIW, I use NAPA's copper anti-seize) on the cylinder head bolts.
Pete
Pete
Going home after a long day
http://farm2.static.flickr.com/1415/132 ... 8754_b.jpg
The fleet at Summit. Mt. McKinley is about 45nm away at 20,320 msl.
http://farm1.static.flickr.com/187/4373 ... 2482_b.jpg
I use waterproof grease on all the bolts I take out, After a rebuid if the motor is maintained properly the head bolts shouldn't have to come out again for at least 20 to 30 years
