Bought a WS Silver Century a few weeks ago and today finished preparing it to run, which it did after a few minutes.
The engine ran well for about 10 minutes then started to vibrate. I killed the engine and tried to re-start. Managed to re-start ok but I noticed there was no wash. Pulled the engine from the water and noticed that the prop was not turning with the engine. There seemed a large amount of fore-&-aft play in the prop shaft. Drained the oil which was a dark green emulsion, removed the spring,washer, collar, end cap and finally the crown wheel. I noticed there was NO rubber oil seal washer(40/236) or Crown wheel thrust washer (1383).
Could this have explained the reason for the crown wheel disengaging from the bevel pinion? I examined the teeth of the bevel pinion which seemed ok.
I examined closely the teeth of the crown wheel which showed signs of pitting and localised corrosion together with some minor damage to the teeth. The profile appeared to be ok. I attach a number of images of the the crown wheel. Is this crown wheel ok to re-use?
Thanks in advance
