Villiers carbs
headcase
Villiers carbs
Post by headcase »
As Villiers carbs were used from the smallest 40 models up to some of the Centuries does anyone know how they were adapted for the different capacities/power outputs ? I expected them to be jetted differently but after looking at the main jets on 13 (!) carbs laying about in my garage the only difference I can find is the old metal float ones are stamped 7J and the later plastic ones 90.
thanks,
Steve
John@sos
Post by John@sos »
Hi Steve,
I have never found any reference to, nor found any fitted with other than the standard parts, as listed on the FAQ page. All Seagulls from Feather weight to CPC had the same Villiers carb? No idea how that works.... You would expect a different jet or throttle slide or something, but no!
Happy Seagulling,
john
SOS
headcase
Post by headcase »
Thanks John. I was worried that fitting a carb off a Featherweight to a Century may cause it to run weak and damage the motor.
figjamidh
not suckinf fuel
Post by figjamidh »
hey can soneone tell me what my prob is my villers carb seems to be filling bowl but not sucking the fuel to keep it running i have blown the carb with air to try and clear it but still nothing only runs on what i spray into carb please please help
