Century 100 cooling ........
pdc1@tesco.net
Post by pdc1@tesco.net »
I've got a beaut of a 40+ that always runs without any overheating ........... but also I've got a Century 100 that seems to pump out the same amount of water as the 40+ when running but it runs very hot and eventually stops after 10 minutes or so.
I'm guessing it may be a cracked head or similar ?? But my question is this. The 40+ and the century have the same impellor size and probably the same volume of water pumping through. But the century must produce more heat being bigger capacity. So with the same amount of cooling as the 40+ is the century bound to run hotter ??
Pete
40TPI
Re: Century 100 cooling ........
Post by 40TPI »
No. It simply means that the water galleries around the cylinder are more than likely choked with rust and crud. It can still appear to pump water like a "fire engine", as they say on the Ebay auctions puffs and be virtually solid inside !
Peter
