Here are some pics of my stripped down FP, it's seized. I was lucky after soaking the gearbox in diesel for a week it became free easily, however the piston is still seized and is proving a bit of a job to move. Unlike some of the guys on the site, I'm not mechanically minded so I'm learning as I go along. I'm listening to the guys and as you can see I've only stripped the bear essentials, i.e. the block is not off.
The whole engine is covered with grime and rust so it'll not be a quick fix as I hope to give it a good clean where possible, and this includes the waterways. I found a lot of muck in the water pipe leading to the block and with some back pressure it now seems pretty clear.
I'm now waiting patiently on the piston which is soaking in diesel which I put in from the connecting rod end. After one day I noticed a drop in the diesel level so I assume it is seeping through as hoped.
I hope these pics will help any other novice to this type of project.
Gerard
You rush down to your local branch of Machine Mart and purchase a three legged Glaze Breaker - about £25.
Return post haste to workshop, attach honing device into electric drill.
You've now only got one bore to clean up. Remove most of rust with stainless kitchen scourer.
Read instructions. No forget that, you're a bloke. Put three legged device into bore. Apply engine oil copiously to stones.
The idea is to just remove scratches, glazing, rustfast marks and leave a surface with 45degree swirls up and down the bore (allows the new rings to bed in)
So, with variable speed drill at fairly slow speed, move device from bottom to top of bore as fast as you physically can. This is essential to achieve the 45degree crosshatching pattern.
Theoretically this should only take moments, but especially with any bore damage or wear I should do it until tired (won't take long), remove device, clean bore with petrol, examine and repeat until satisfied.
The deglazing stones only remove a fine top surface - you're not reboring!
When delighted, wash out bores thoroughly with soap and water to remove every last trace of grinding paste.
The new rings are specially shaped and won't require sizing to the bore. They can be fitted fairly easily without a ring compressor.
After its going brrrmm, brrrrmmm, purchase a compression gauge and report back with your reading . . .
Last edited by rosbullterier on Mon Feb 08, 2010 11:22 pm, edited 2 times in total.
Well it's so bloody cold I need to huddle over a warm computer. My Winter Heating Payment must be late.
However, we still need to elicit the postal area of said owner of this rusty old 40+ - one assumed the possibility of an Antipodian/Polynesian thread with the supposed Maori mask.
But do the tentacles of Machine Mart extend around to New Zealand?
