Removing Dents from Brass Tank
DaveF
Post by DaveF »
Hi,
I've got a 73 Forty Plus Mk II with a brass fuel tank. Some good dents in the end plates (stamped with "seagull". Has anyone attempted to remove the end plates with heat to loosen the solder (I'm assuming the plates are soldered on)? Then one could remove the dents, then resolder.
Thanks,
Dave F
outboard
Re: Removing Dents from Brass Tank
Post by outboard »
Look at the subject "Safe way to cut tanks", this is a topic about taking the ends off the tank and the guys with experience have explained it fully.
DaveF
Post by DaveF »
Thanks! First time to this site and while waiting for a reply I found the same link. Excellent detailed post on the repair. Think I'll do this.
Cheers,
Dave F
