I was suspicious of my Century 100 gearbox leaking oil in large amounts, especially when the motor is lifted up. After some test tank runs, I checked the oil levels, and as was said once, "if its not leaking oil, its not a Seagull--- or empty. Mine was empty. I pulled of the gearbox and form the motor and a diagram from internet and discovered a few things, some of them not belonging in the box. My problem with the oil leak was the pinion gear bush. Its really worn and the pinion is wobbly. I tried my best to get the bush out with the pinion, but gave it up, even after heating the gearbox. I finally decided to stuff a brass shim into the brass bush. It certainly stopped the wobble.
And the oil dripping out when I tilt the motor. The fit is pretty tight, but the problem is the shim don't go all the way through the brass bush, its simply too tight. I acknowledge this as a temporary repair and the jackpot will be to remove the bush and replace, perhaps custom made to fit the shaft of the pinion.
Now the pinion do have some wear on the tips, most likely from slipping over the crown gear. And this is where the extra parts appear. On the forty plus gearbox, part #12 is brass according to me, but there was/is an extra steel washer added. I removed this washer since it appears to have cut quite badly into the brass seal/bearing part #13. The problem was that then whole crown gear and shaft moved back to such an extend that when holding the drive shaft, the pinion starts to slip. Is that just normal wear on the brass bushes or some other misalignment? There was another steel washer on the other side of the crown gear. I suppose it was to prevent the crown from pushing too hard into the pinion?
Is this gearbox worth repairing with so many worn parts? What should I be looking out for?
